Garmin Nuvi 2589LMT Battery Replacement
  1. Garmin Nuvi 2589LMT Battery Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 2589LMT Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is held in place by adhesive tape on the underside of the battery.
    • Use the opening tools to gently pry underneath the battery and lift upwards to remove the battery.
Adam Ferraro
crwdns2935283:010/04/16crwdne2935283:0
947 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-2, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 1-2, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S1G2
Where can I buy this battery
Stan Levin
stan levin - crwdns2934203:0crwdne2934203:0
where can I buy this battery
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
Hans-Joachim Böhnke - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,263
