Garmin Nuvi 255W Logic Board Replacement
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 255W Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the logic board form the battery by pulling out the cable.
Anjelica
crwdns2935283:004/11/10crwdne2935283:0
579 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-90, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-90, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G90
crwdns2942667:0crwdne2942667:0 10,641
