The tools you will need are a T5 Torx screwdriver, plastic opening tool, and soldering equipment. The speaker might be glued to the back of the device and is connected to the motherboard.
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Using a plastic opening tool, pry open the device along this separation.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Using a plastic opening tool, wedge the speaker from the device.
Using a soldering iron, desolder the wire connection between the speaker and the device.
