The tools needed are T5 Torx Screwdriver, plastic opening tool, and a soldering iron. In order to take out the motherboard you will need to disconnect the battery and the speaker from it also.
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Using a plastic opening tool, pry open the device along this separation.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Using a plastic opening tool pry the battery away from the device.
Pull the battery-motherboard connector away from the motherboard.
Using a plastic opening tool, wedge the speaker from the device.
Using a soldering iron, desolder the wire connection between the speaker and the device.
Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
Using a plastic opening tool, pry the motherboard away from the device.
