This guide will show you how to disassemble the Garmin Nuvi 1390LMT GPS to replace the logic board.
Snap the plastic cover off using a plastic opening tool.
Remove the four black 11 mm T5 torx screws.
Pop the screen cover off with a plastic opening tool.
Gently pull the wire ribbon connecting the screen to the logic board from the plug.
Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
Disconnect the harness between the battery and the logic board.
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
How many pins is this logic board for that exact logic board display scren
