Garmin GPS V Front Plate Replacement
  1. Garmin GPS V Front Plate Replacement, Logic Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Logic Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Logic Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Front Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Front Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Front Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Front Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Front Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin GPS V Front Plate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Front Plate Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
  8. Garmin GPS V Front Plate Replacement, Button Pad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Button Pad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Button Pad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the button pad off of the front plate.
  9. Garmin GPS V Front Plate Replacement, Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Display: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin GPS V Front Plate Replacement, Display: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the front plate of the device so the display board is facing up.
    • With the spudger, gently work your way around the display assembly.
    • NOTE: The display assembly is composed of three parts and is glued to the case. Be careful to not separate it when prying it out.
    • Pry the display free of the front plate.
  10. Garmin GPS V Front Plate Replacement, Front Plate: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the display removed, the front case of the Garmin GPS can be replaced.
Connor
crwdns2935283:001/23/12crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-25, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 3-25, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S3G25
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 929
