The motherboard is an essential component of any electronic device. Always use caution when working on these components.
Place the watch on a hard surface with the screen facing down.
Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
Pry the old battery out using a plastic spudger.
Unscrew the two T4 6 mm screws located on both sides of the motherboard.
Lift the motherboard up using a plastic spudger.
Flip the ZIF connectors using a plastic spudger tool.
Remove the motherboard.
