Garmin Fenix 5 Cleaning
  1. Garmin Fenix 5 Cleaning, Front screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 5 Cleaning, Front screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap
    • Power-off the device
    • Remove the screws on the front using the Torx T4 screwdriver
  2. Garmin Fenix 5 Cleaning, Rear screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the rear using the Torx T6 (or TR6) screwdriver
  3. Garmin Fenix 5 Cleaning, The small arc: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 5 Cleaning, The small arc: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small grey arc on the top of the device with the tweezers
  4. Garmin Fenix 5 Cleaning, Remove the screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the tweezers, remove the pin connector linked to the screen
    • Remove the screen
  5. Garmin Fenix 5 Cleaning, Free the motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 5 Cleaning, Free the motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 screws on the motherboard using the PH #000 screwdriver
  6. Garmin Fenix 5 Cleaning, The sensor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 5 Cleaning, The sensor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 screws holding the sensor between the buttons on the right side of the case
    • With the tweezers, remove the sensor and detach the case from the motherboard
  7. Garmin Fenix 5 Cleaning, Gasket and buttons: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Fenix 5 Cleaning, Gasket and buttons: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Fenix 5 Cleaning, Gasket and buttons: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seal around the circumference of the watch casing, as you will be handling the casing a lot and you don’t want to risk tearing the gasket.
    • Using the tweezers, remove the circlips around every button very carefully.
    • When the circlips are removed, you can pull the buttons off. Do this step carefully because you will also find a return spring inside every button hole
  8. Garmin Fenix 5 Cleaning, Clean case and buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the case, including the hole of the buttons
    • Clean the buttons and the springs
    • (OPTIONAL) You can lubrificate the buttons before re-inserting them in the case
    • Reassemble the watch
Garmin Boy
crwdns2935283:004/28/21crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
crwdns2947412:014crwdne2947412:0
Thanks for that info. In looking at the pictures, I can’t tell which piece is the battery. Do you think it can be easily replaced? Or is it soldered in? Thanks.
Patrick Chang - crwdns2934203:0crwdne2934203:0
Hi,
the battery is visible in the step 5 and step 6.
It is linked to the mainborad with a connector, It’s not soldered.
It’s glued to the back cover but, in my opinion, it can be easy replaced.
The battery type is "361-00097-00"
The nominal specifications are 255mAh, 0.97Wh and 3.8V
On ebay you can find a new battery: https://www.ebay.it/itm/283519139846?has...
I hope this can help
Garmin Boy -
Maybe do You know where to purchase a gaskets?
Edgaras Tamošauskas - crwdns2934203:0crwdne2934203:0
Unfortunately, I don’t know where you can find it.
I’ve searched on my favourite websites with no luck.
Garmin Boy -
Question: do I need to disasassemble the screen to change only the battery? Can I just access to it by the rear cover?
Thanks for the info!
Cristóbal Sabroe Yde - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 407
crwdns2942667:0crwdne2942667:0 16,901
