This guide will give you all the necessary steps to change your old motherboard for a new one.
Remove the five 7mm screws with H1.3 hex screwdriver.
Use a plastic opening tool to remove the face of the device to expose the inner components.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect this ribbon from the motherboard using tweezers.
Using a T5 screwdriver, remove the two 5mm screws.
Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
Disconnect wires connecting battery to motherboard.
The battery is glued to the motherboard and will need pried off with a nylon spudger.
Now attach battery to new motherboard and reassemble.
crwdns2935229:05crwdne2935229:0
And where would one source replacement motherboard?
donde puedo encontras placa.madre reeemplazo????
