This guide will give you step-by-step instructions on how to quickly swap out that old battery for a new one.
Remove the five 7mm screws with H1.3 hex screwdriver.
Use a plastic opening tool to remove the face of the device to expose the inner components.
There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Proceed to disconnect the ribbon from the motherboard using tweezers.
Using a T5 screwdriver, remove the two 5mm screws.
Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
Disconnect wires connecting battery to motherboard.
The battery is glued to the motherboard and will need pried off using the nylon spudger.
crwdns2935229:042crwdne2935229:0
crwdns2947412:029crwdne2947412:0
Does anybody do It in a fenix 5?
Same question. Fenix five /+ guide on the way?
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
