If the battery is not holding a charge as long as it should, or is failing to charge at all, use this guide to replace the battery. You will need a T6 Torx screwdriver, a T5 Torx screwdriver, and a spudger.
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Carefully lift the face off the watch base.
Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
Locate the antenna, which is located on the motherboard.
Carefully remove the antenna, and set it aside.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a T5 screwdriver to remove the two silver 1.4 mm screws from the motherboard.
Lift the watch and turn it over one hand. The motherboard should fall out easily.
Using the spludger, separate the battery from the motherboard, which are both held together with a mild adhesive. Note that the battery connector lifts upward away from the circuit board by simply lifting the wires up should pop the connector.
crwdns2935229:024crwdne2935229:0
crwdns2947412:037crwdne2947412:0
Ruined my watch… The battery connection socket ripped off with the battery connector…
I have taken apart phones and laptops in the past without issue, so I am not inexperienced by any means. I was as careful as possible.
John Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Sounds like it may have had a factory defect. I did the same fix and it worked fine, just like any other computer or phone.
Hamilton Cooper - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Excellent guide - thanks! My Fenix3 wasn't charging any more so following your guide I replaced the ‘dead’ battery with a new one with ease. However, when reassembled, the new battery worked but would not charge. I took it apart again, and found slight corrosion or gunk on the motherboard terminals where they contact the inner side of the charging pins. After a good clean with meths and a cotton bud I popped the original battery back in, reassembled it, and hey presto! it started charging! Very happy!
Nick Coldham - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I appreciate the guide as my Fenix 3 after 6 years of owning it could barely make it 24 hours without charging it.
The only thing I’d add to the guide is that you can reuse the adhesive from the existing battery as it’s only double-sided tape. Other than, it went flawless!
Roy J. Villarreal III - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for this. Just did it successfully. A quick note, when you are separating the battery from the motherboard, it pulls up/perpendicular to the device and not parallel to it as I had initially thought. Luckily I did not break the battery connector to the motherboard. When I put it back in I needed to push it towards the motherboard to properly seat it. Look closely to make sure no part of the connector is sticking up, even a hair or it will not work.
Michael Reid - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
