You will be removing the existing straps on the watch in order to replace a damaged strap or simply to put a new style of strap on. The tools you will need for this fix is a Torx T9 screwdriver.
Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
