Garmin Fenix 2 Housing Replacement
  1. Garmin Fenix 2 Housing Replacement, Watch Straps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
    No way is this a two minute, easy to do exercise. The screws connect to the bar. The bar rotates. Once the first screw is out, the second is very difficult to extract because there is no leverage to use when attempting to turn the remaining screw. Even the simplest internet post recommends a vise.
    chiphoyt - crwdns2934203:0crwdne2934203:0
  2. Garmin Fenix 2 Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
  3. Garmin Fenix 2 Housing Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Fenix 2 Housing Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Fenix 2 Housing Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  4. Garmin Fenix 2 Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 2 Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  5. Garmin Fenix 2 Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 2 Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
    I am looking at the battery you suggested on eBay, and it appears that there are wires attached to it. Exactly where do these wires connect? Do they require soldering in place somewhere?
    Jamie - crwdns2934203:0crwdne2934203:0
    Good information, but :
    - spudger not really needed, nail is enough.
    - missing the one regarding the need for a soldering iron ! The old battery needs to be unsoldered and the new one soldered to the inside wiring. Not so difficult but soldering iron needed !
    Got a spare battery on eBay (vendor is http://akku-wechsel.de). Delivery was very fast. After replacement I went from 6~8 hours life to 3~4 weeks :) So happy with the upgrade !
    Pierre Colin - crwdns2934203:0crwdne2934203:0
  6. Garmin Fenix 2 Housing Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry open the power ribbon from the main board.
  7. Garmin Fenix 2 Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
    This screw is smaller than the .8mm, and cannot be removed with the Torx T9 screwdriver
    David Trame - crwdns2934203:0crwdne2934203:0
  8. Garmin Fenix 2 Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry the motherboard out of the housing.
  9. Garmin Fenix 2 Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once removed simply separate the digitizer from the main board.
  10. Garmin Fenix 2 Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 2 Housing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
  11. Garmin Fenix 2 Housing Replacement, Display: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display is also ready to be replaced.
  12. Garmin Fenix 2 Housing Replacement, Housing: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 2 Housing Replacement, Housing: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger tool to pry the soundboard out of its housing.
  13. Garmin Fenix 2 Housing Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gasket seal from the housing.
  14. Garmin Fenix 2 Housing Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all your components are removed the housing with buttons is ready to be repaired/ replaced.
crwdns2935229:05crwdne2935229:0
Brandon Barger
crwdns2935283:002/13/16crwdne2935283:0
1.219 crwdns2915208:0crwdne2915208:0
IUPUI, Team 54-4, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 54-4, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S54G4
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
Antenor Heleodoro dos Santos - crwdns2934203:0crwdne2934203:0
do you know where i can find atmospheric pressure and temperature sensors?
marco turati - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,498
