Garmin Edge 830 Back Cover Replacement
  1. Garmin Edge 830 Back Cover Replacement, Touch Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
    I have a 820 is the same process used?
    Gary Roy Hogg - crwdns2934203:0crwdne2934203:0
  2. Garmin Edge 830 Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
    Does the glue have to be replaced? If so what type of glue?
  3. Garmin Edge 830 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Back Cover Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Back Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 830 Back Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Back Cover Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 Back Cover Replacement, Back Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all previous steps are completed, you will be left with the back cover.
Alden Gibbs
crwdns2935283:003/21/22crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 3-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 3-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S3G2
crwdns2935297:013crwdne2935297:0
What are the steps required to put the screen back on? What glue should we use and how?
Odhita Kamayana - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 1,807
