Garmin Edge 830 Back Cover Replacement
  1. Garmin Edge 830 Back Cover Replacement, Touch Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Back Cover Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Back Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 830 Back Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Back Cover Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 Back Cover Replacement, Back Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all previous steps are completed, you will be left with the back cover.
Alden Gibbs
crwdns2935283:003/21/22crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 3-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 3-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S3G2
crwdns2935297:013crwdne2935297:0
What are the steps required to put the screen back on? What glue should we use and how?
Odhita Kamayana - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 2,156
