Garmin Edge 530 Motherboard Replacement
  1. Garmin Edge 530 Motherboard Replacement, LCD Screen Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
  2. Garmin Edge 530 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
  3. Garmin Edge 530 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
  4. Garmin Edge 530 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
  5. Garmin Edge 530 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
  6. Garmin Edge 530 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
  7. Garmin Edge 530 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
  8. Garmin Edge 530 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
Harrison Stafford
crwdns2935283:002/22/22crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-1, Hunter Spring 2022 crwdns2935289:0Clemson, Team 2-1, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S2G1
crwdns2935297:017crwdne2935297:0
Can you guys do a repair on the buttons? I had a stuck button, I popped it off, now I can't get it back on :(
Jonathan Fisher - crwdns2934203:0crwdne2934203:0
Guide failed to mention to detatch the ribbon cable from under the copper tape after removing the connector at step 5
Paul Jackson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 4,451
