If your Garmin Smartwork 50 LMT has trouble powering on, holding a charge, or shows battery warnings, you may need to replace the internal battery using this guide.
The battery connects directly to the mainboard, so this repair can also help if the device shuts off unexpectedly or only works when plugged in.
The steps are simple, but be gentle when opening the case to avoid damaging internal cables.
Before you begin the repair, power off the GPS and unplug the charger.
Use a T5 Torx screwdriver to remove the four screws from the bottom case.
Insert an opening tool into the seam between the top and bottom case.
Slide it around the perimeter of the device to release the clips holding them together.
Separate the top and bottom of your GPS.
Flip the device so that the motherboard and the battery are facing up.
Use the angled tweezers to unplug the battery connector from the motherboard.
Use an opening tool or spudger to gently pry the battery out, being careful not to puncture or bend it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
