In the event that the battery dies of your Garmin Dezl 770LMT, due to heat or damage, it can be replaced. This can assist those who may not wish to replace their device.
Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
Use the spudger to pry apart the screen from all around the device.
Using a metal spudger, carefully pry the battery from the device.
Grasp the wire near the mother board and gently lift to detach the battery.
crwdns2935229:05crwdne2935229:0
