This guide will explain how to open your Garmin, detach the battery from the motherboard, and remove the battery from the device safely and quickly.
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
Using a metal spudger, pry the device apart.
Turn the device over, laying it on its back with the screen facing upwards.
Lift the front panel away from the silver part of the back panel.
Use a nylon spudger to pry the battery from the device.
Grasp the battery wire near the motherboard and lift upward to detach the connector.
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
you have to be more careful with your stuff dude..
Thanks for the tutorial, it was very helpfull. I've changed the battery without any problem. Good job
