Garmin Dash Cam 20 Motherboard Replacement
  1. Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
Jesse Hillman
crwdns2935283:010/04/16crwdne2935283:0
757 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-1, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G1
hello Im looking for a replacement part for this Dash Cam, the socket piece. Do you have any of them?
rdlr2112@gmail.com
rushfanbytor - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 973
