            Rotate the Dash Cam to where the socket faces you.
            Remove the 9 mm screw using the Torx T6 screwdriver.
            Rotate the Dash Cam to where the product information faces you.
            Remove the two 5 mm screws using the Torx T5 screwdriver.
            Remove top case from the bottom case.
            Remove the two 5mm screws using the Torx T5 screwdriver
            Use the nylon spudger to pry the corner of the case off of the motherboard.
            Remove the metal case off of the motherboard.
            Remove the three 5 mm screws using the Torx T5 screwdriver.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use tweezers to remove the connector on the top right of the motherboard.
            Remove the motherboard from the case and flip to reveal SD connection.
            Use tweezers to remove the connector next to the SD card slot.
            The motherboard is now removed aside from the copper strip and its connector.
            Disconnect from the front case and the copper strip.
hello Im looking for a replacement part for this Dash Cam, the socket piece. Do you have any of them?
rdlr2112@gmail.com
