Garmin Dash Cam 20 Battery Replacement
  1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the green tape overlying the pin connector with tweezers.
    • Remove the pin connector using tweezers.
    • Do not break black cord connection between motherboard and metal mount (orange circle).
  8. Garmin Dash Cam 20 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Dash Cam 20 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step shows the use of an incorrect tool. Only use ESD safe tools when handling the battery.
    • With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
Jesse Hillman
crwdns2935283:010/04/16crwdne2935283:0
757 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-1, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G1
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Bradley Hyman - crwdns2934203:0crwdne2934203:0
Yeah I agree
Yousef Ghalib -
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
pro c - crwdns2934203:0crwdne2934203:0
The problem I am having is that every time my Garmin 20 starts it goes right into the menu mode and does not automatically start recording. I was using this dash cam as my rear camera so I can't go through the menu every time I start my car. I replaced the battery with a new one hoping this was the problem but a new battery did nothing to help. Any ideas?
Bruce Allen - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,430
