This guide will walk users through removing the Dash Cam's casing revealing the internal components, allowing access to rechargeable battery.
            Rotate the Dash Cam to where the socket faces you.
            Remove the 9 mm screw using the Torx T6 screwdriver.
            Rotate the Dash Cam to where the product information faces you.
            Remove the two 5 mm screws using the Torx T5 screwdriver.
            Remove top case from the bottom case.
            Remove the two 5mm screws using the Torx T5 screwdriver
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Remove the green tape overlying the pin connector with tweezers.
            Remove the pin connector using tweezers.
            With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Yeah I agree
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
The problem I am having is that every time my Garmin 20 starts it goes right into the menu mode and does not automatically start recording. I was using this dash cam as my rear camera so I can't go through the menu every time I start my car. I replaced the battery with a new one hoping this was the problem but a new battery did nothing to help. Any ideas?
