Be very careful when handling connector wires, as they are incredibly easily broken. This guide is unique only in removing the circuit board from the screen.
Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
Remove the orange gasket.
Remove the screen and motherboard assembly from the case.
Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
Remove the screen from the golden metal clip.
Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
Remove the connector from the motherboard by pulling it free at the base.
Remove the screen from the motherboard.
Remove the motherboard from the screen.
