crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide directs the user in removing the back cover and battery. Keep in mind that this replacement requires generous prying and a consideration of tiny and delicate parts.
Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
On the back cover use a plastic opening tool to remove the green tape retaining the battery.
Remove the green tape shrouding the battery connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
Remove the battery.
Remove the green tape on the back of the battery, it can be reused later.
crwdns2947412:08crwdne2947412:0
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
