GameStop GS3 GameCube Controller joysticks replacement
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GameStop GS3 GameCube Controller joysticks replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Andrew Gonsalves
crwdns2935283:010/20/16crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 crwdns2935289:0UMass Dartmouth, Team 3-5, Isaacson Fall 2016crwdne2935289:0
UMASSD-ISAACSON-F16S3G5
crwdns2942667:0crwdne2942667:0 1,381
