The USB-C Plug connects the mobile phone to the GameSir X2 Type-C and is the only source of connection from the mobile phone to the controller. GameSir designed the USB-C plug to pivot 51 degrees to prevent damage to mobile phone charging ports while inserting and removing the device.
If your phone fails to connect to the Gamesir X2 Type-C, the USB-C plug may need replaced. Follow this guide to replace the plug. Before replacing the plug, review the troubleshooting page. More than likely a bad connection can be fixed without replacing the USB-C plug.
Turn the device so the back faces you.
Remove the eight 6 mm T6 Torx screws.
Use a straight edge to remove the rubber pad on the front of the device.
Remove the four 4.5 mm screws with a Phillips #000 screwdriver.
Use a straight edge to pry open the controller, following the seam on the controller.
Remove the two 6mm Phillips head screws.
Gently remove the plastic bracket from the plug.
Identify where the ribbon wire connects to to the motherboard.
Flip the black locking ZIF flap holding the ribbon wire in place to the upward position.
Gently remove the ribbon cable away from the motherboard socket.
Once the cover is off of the plug and the ribbon wire is released from the flap, gently pull the USB-C plug away from the device.
