GameSir T4 Pro Motherboard Replacement
  1. GameSir T4 Pro Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GameSir T4 Pro Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GameSir T4 Pro Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir T4 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the USB-C charger with tweezers.
    • Do not pull on the wires.
  3. GameSir T4 Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the battery off of the motherboard, with care not to bend the cell.
    • The battery is secured with adhesive. If the adhesive is stubborn, apply a small amount of high-concentration alcohol under the battery to loosen the adhesive.
    • Grip the white battery connector with tweezers and pull it directly out of its motherboard port.
  4. GameSir T4 Pro Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir T4 Pro Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 7.1 mm Phillips #0 screws from the motherboard.
    • Remove the two 7.1 mm Phillips #0 screws that secure the trigger assemblies.
  5. GameSir T4 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the controller.
Yamini Sri
crwdns2935283:004/01/24crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Spring 2024 crwdns2935289:0IUPUI, Team 1-2, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S1G2
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 612
