GameSir G7 SE Joystick Module Replacement
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Joystick Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Joystick Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Joystick Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Joystick Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
  5. GameSir G7 SE Joystick Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
  6. GameSir G7 SE Joystick Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
    What joystick module is compatible with the G7 SE, and is it of the same quality as the original?
    Gabriel Rosa - crwdns2934203:0crwdne2934203:0
AJ Saks
crwdns2935283:001/23/24crwdne2935283:0
150 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G6
Where to get the replacement parts?
Isaiah Hackworth - crwdns2934203:0crwdne2934203:0
Where do you get the replacement parts from?
michaeljhs - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 424
crwdns2942667:0crwdne2942667:0 4,180
