GameSir G7 SE Joystick Module Replacement
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Joystick Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Joystick Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Joystick Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Joystick Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
  5. GameSir G7 SE Joystick Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
  6. GameSir G7 SE Joystick Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
AJ Saks
crwdns2935283:001/23/24crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G6
Where to get the replacement parts?
Isaiah Hackworth - crwdns2934203:0crwdne2934203:0
Where do you get the replacement parts from?
michaeljhs - crwdns2934203:0crwdne2934203:0
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 115
crwdns2936753:030crwdne2936753:0 616
crwdns2942667:0crwdne2942667:0 6,593
