Game Boy Speaker Replacement
crwdns2936621:0crwdne2936621:0
  1. Game Boy Speaker Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Speaker Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Speaker Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Triwing screws from the back of the device.
    The Game Boy uses Y1 screws for the outer case
    Rumia1 - crwdns2934203:0crwdne2934203:0
  5. Game Boy Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Speaker Replacement, Speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10 Phillips #00 screws from the motherboard.
  9. Game Boy Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
    • Use caution when lifting the board since the speaker is attached.
  10. Game Boy Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the two wires connecting the speaker to the motherboard.
    • Remove the speaker.
    • If you're new to soldering, refer to this guide for tips that will help with desoldering the speaker wires and/or soldering the new ones in place.
crwdns2935229:016crwdne2935229:0
Andrew Tramposch
crwdns2935283:006/24/10crwdne2935283:0
2,258 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-2, Johann Summer 2010 crwdns2935289:0Cal Poly, Team 3-2, Johann Summer 2010crwdne2935289:0
CPSU-JOHANN-R10S3G2
crwdns2935297:035crwdne2935297:0
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
Paul - crwdns2934203:0crwdne2934203:0
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
Jeff Suovanen -
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 209
crwdns2942667:0crwdne2942667:0 34,592
