Game Boy Screen Replacement
  1. Game Boy Screen Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Screen Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Triwing screws from the back of the device.
    The Game Boy uses Y1 screws for the outer case
    Rumia1 - crwdns2934203:0crwdne2934203:0
  5. Game Boy Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Screen Replacement, Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten screws that connect the circuit board to the outer case.
    The screen/controller board uses 10 size 1 philips head screws
  9. Game Boy Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the circuit board from the outer case using a plastic opening tool.
    • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
  10. Game Boy Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disengage the the three plastic clips that secure the screen to the circuit board.
    I didn’t find this step necessary as the plastic screen holding unit is separate from the screen.
    skrolikowski - crwdns2934203:0crwdne2934203:0
  11. Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the circuit board over revealing the device screen.
    • Remove the two screws connecting the screen and the circuit board.
    • Follow the video instructions to desolder the display connectors and replace your screen.
crwdns2935229:046crwdne2935229:0
Andrew Tramposch
crwdns2935283:006/24/10crwdne2935283:0
2 258 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-2, Johann Summer 2010 crwdns2935289:0Cal Poly, Team 3-2, Johann Summer 2010crwdne2935289:0
CPSU-JOHANN-R10S3G2
crwdns2935297:035crwdne2935297:0
crwdns2947412:014crwdne2947412:0
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - crwdns2934203:0crwdne2934203:0
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham -
Replacement reflective LCDs are not possible to find. You can either purchase a screen salvaged from an old DMG, or get a brand new backlit LCD replacement.
mars -
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - crwdns2934203:0crwdne2934203:0
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - crwdns2934203:0crwdne2934203:0
I agree. I have horizontal lines, and it has been difficult to find out if it is fixable or if it is damaged beyond repair. I have found no instructions on how to repair this, only one website saying it cannot be fixed and you shouldn't try.
mars -
Where do I buy a replacement screen for a 1989 game boy?
Nathan Thurston - crwdns2934203:0crwdne2934203:0
i suggest maybe going on ebay and finding a gameboy thats either just for parts or has a working screen and desoldering it
Ethan Amos -
Habt ihr einen guten Tipp, wo man ein neues LCD herbekommt?
Car W - crwdns2934203:0crwdne2934203:0
I tried following the video and ended up with burned tabs and melted plastic. Basically it’s all ruined. OP does a terrible job.
Daniel Powers - crwdns2934203:0crwdne2934203:0
will this guide work to install a backlit LCD for the Game Boy? I have this Rips v4 backlit IPS LCD, and I figured I might as well install it.
if not, that's alright. I'll just find another guide.
Bella Marie - crwdns2934203:0crwdne2934203:0
AFAIK you can follow through the disassembly guide up to step 10 no problem, then it depends if you bought the full kit you simply swap the old screen and big PCB with the new ones; if you're planning to use the original GB case, notice you'll have to do some mods in order to fit in the new screen. Also, you might have to solder the speaker on the PCB. Here's a video you may want to check out when you're done disassembling the GB and will be ready to start installing the screen upgrade: https://www.youtube.com/watch?v=FMIJTbPe...
Simone -
bonjour ou puis je trouver l'ecran LCD ?
merci
nelly viaud - crwdns2934203:0crwdne2934203:0
I have the horizontal lines issue on my DMG, and it is unclear if this issue can be resolved. Unfortunately, replacement reflective screens are not available unless you salvage one from another DMG, which is not ideal. You can get brand new backlit LCDs, which I admit would be advantageous in some situations, but backlit LCDs are difficult to see in direct sunlight. While I would like to see brand new reflective LCDs, I don't expect to see them because there isn't much of a market for them and no one is in the business of losing money.
mars - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 57
crwdns2936753:07crwdne2936753:0 384
crwdns2936753:030crwdne2936753:0 1,538
crwdns2942667:0crwdne2942667:0 152,196
