Game Boy Screen Replacement
    1. Game Boy Screen Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Switch your Game Boy off and remove the cartridge.
    2. Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
      • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
      • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
    3. Game Boy Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
      • Dispose of used batteries properly!
      • Remove the batteries from your Game Boy before storing it for more than a month or so.
    1. Game Boy Screen Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six Triwing screws from the back of the device.
    2. Game Boy Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently separate the device's front casing from the back casing after you remove the screws.
      • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
    3. Game Boy Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the front side of the casing down to expose the ribbon cable connector.
    4. Game Boy Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
      • Separate the front and back casings.
    1. Game Boy Screen Replacement, Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the ten screws that connect the circuit board to the outer case.
    2. Game Boy Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the circuit board from the outer case using a plastic opening tool.
      • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
    3. Game Boy Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disengage the the three plastic clips that secure the screen to the circuit board.
    4. Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Game Boy Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the circuit board over revealing the device screen.
      • Remove the two screws connecting the screen and the circuit board.
      • Follow the video instructions to desolder the display connectors and replace your screen.
crwdns2935229:050crwdne2935229:0
Andrew Tramposch
crwdns2935283:006/24/10crwdne2935283:0
2.384 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-2, Johann Summer 2010 crwdns2935289:0Cal Poly, Team 3-2, Johann Summer 2010crwdne2935289:0
CPSU-JOHANN-R10S3G2
crwdns2947412:014crwdne2947412:0
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Replacement reflective LCDs are not possible to find. You can either purchase a screen salvaged from an old DMG, or get a brand new backlit LCD replacement.
mars - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 55
crwdns2936753:07crwdne2936753:0 386
crwdns2936753:030crwdne2936753:0 1,630
crwdns2942667:0crwdne2942667:0 183,855
