Galaxy Tab S 10.5 Battery Replacement
  1. Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
    • Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
  5. Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 2mm screws Phillips #000 screws surrounding the battery.
  6. Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the plastic opening tool between the frame and battery.
    • Move the plastic opening tool in a downward motion, away from the battery to bring the battery out of the device.
  7. Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Tab S 10.5 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the battery and disconnect the plug to remove the battery.
crwdns2935229:084crwdne2935229:0
Jordan Soto
crwdns2935283:008/26/15crwdne2935283:0
3,297 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 3-2, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S3G2
crwdns2935297:020crwdne2935297:0
crwdns2947412:020crwdne2947412:0
where is a good place to buy a replacement battery?
brianference - crwdns2934203:0crwdne2934203:0
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Miguel Ángel - crwdns2934203:0crwdne2934203:0
Great guide! Thanks a lot!
Markus - crwdns2934203:0crwdne2934203:0
I bought a battery but am afraid to do the replacement myself. Where can I take the tablet to have it done?
Barb - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 212
crwdns2942667:0crwdne2942667:0 102,579
