Galaxy J3 Prime LCD Screen Replacement
crwdns2936621:0crwdne2936621:0
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
crwdns2935229:09crwdne2935229:0
Brian Brown
crwdns2935283:009/26/16crwdne2935283:0
393 crwdns2915208:0crwdne2915208:0
great guide, this really helped
anonymous 591 - crwdns2934203:0crwdne2934203:0
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - crwdns2934203:0crwdne2934203:0
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 6,950
