GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard
  1. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your Computer is off before starting!
    • Unplug your desktop from the wall outlet.
    • Turn your desktop so you have access to the back of the device.
  2. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Switch off the PSU to prevent power flow.
    • Unplug your desktop to prevent any power flow.
  3. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the two 15 mm screws on the glass panel side and remove the panel.
  4. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the glass panel, by sliding it towards yourself.
    • The panel contains glass so be gentle with it!
    • The GPU is highlighted.
    • Using the Phillips #0 screwdriver, remove the three 14 mm screws connecting the GPU to the case.
    • Unplug the power cable on the GPU.
  5. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the GPU from the power supply, since we need to remove anything connected to it.
  6. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 to remove the three 14mm Phillips screws from the GPU and motherboard so we can remove the GPU later.
  7. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the tab to unlock the GPU.
    • The tab unlocks easily, so don't apply too much force.
  8. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the old GPU out.
    • The PCI-E slot is now empty for a new GPU.
  9. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Line up the GPU with the PCI-E Slot.
    • Push the GPU in, make sure to line it up properly with the PCI-E and the rear end of the case.
    • The tab will click in when you push the GPU in.
  10. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw the three 14 mm Phillips screws back in using the Phillips #0 screwdriver.
  11. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the 8-Pin Male Cable from the PSU into the GPU to power it when we turn it on.
  12. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the glass panel back in.
  13. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, screw in the two 15 mm screws back into the case to lock the panel into place.
  14. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect the female part of the power cord into the PSU.
    • Turn on the switch and power on your PC.
The brand or generation of GPU you intend to install does not matter, as long as it can fit the PCI-E slot located on your motherboard.
Faiz Khan
crwdns2935283:001/19/21crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
York University, Team S2-G11, O'Regan Winter 2021 crwdns2935289:0York University, Team S2-G11, O'Regan Winter 2021crwdne2935289:0
YORK-O'REGAN-W21S2G11
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,726
