GHD hair straightener repair guide
  1. GHD hair straightener repair guide, Overview: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is a generic guide for repairing the GHD hair straighteners listed in the introduction. In the interests of not re-inventing the wheel, this guide is a series of links to a 3rd party web site (GHD-Repair) that have many detailed video guides for repair and can also provide certified parts.
    • The most common faults are
    • Power cable break. Because of the way it swivels, the joint wears and you get intermittent or complete no-power.
    • Due to the wear and tear from use (and also wrapping cables around irons), the cable can break. Particularly where the cable enters the strain relief at each end. The sockets (apart from the type 2 ones) are pretty reliable. If the cable fails internally as a short, there might be sparking and a blown plug fuse
    • Thermal Fuse. Often the plug fuse (UK) will blow also. The symptoms are the unit not powering on at all. Quite often a faulty thermistor will cause the thermal fuse to blow. So if you only change the thermal fuse, it could blow again. To be safe, change the thermistor at the same time as the thermal fuse
    • The thermal fuse is on the back of the plate(s) and fails due to a broken element or a detached thermal fuse (depending on model). The thermal fuse only fails for no reason on the 3.1B model, because they speced it at 218degC rather than 227degC. On newer models (Eclipse onwards) there might be signs of life, even if the thermal fuse has tripped
    • Thermistor. Usually the unit powers on and beeps, but no heat in the plates, unless it has also caused the thermal fuse to fail, in which case see bullet point above
    • R8/R11 Resistor failure on mk4 and mk5 is VERY common. Easy to fix but can also cause heater element to fail as well. See this link for more details
    • Other common faults can be found at this link.
    • For UK repairers, GHD-Repair can provide certified spares/parts for parts that can be replaced. Use this link and select the model you require a part for. The parts come prepared for use and no need to additionally buy things like thermal paste and kapton tape. Within each spares section, there are videos on how to replace the part
    • Beware of other suppliers for thermal fuses. They should be 227degC rated. Other suppliers use 240degC and these can be dangerous
    • For those that are unsure about doing a repair themselves GHD-Repair offer a fixed price repair service (UK only). See this link for details
Simon G
crwdns2935283:009/27/24crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
North Hampshire Repair Cafe crwdns2935289:0North Hampshire Repair Cafecrwdne2935289:0
Local Repair Groups
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 795
