GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket
  1. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Drain Tube: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can do this! It will be hard to hurt yourself or damage your fridge by trying to do this. There really is not anything to break. It should take about a half hour.
  2. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Presenting Problem--Ice ring under basket: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Presenting Problem--Ice ring under basket: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This mess kept appearing under my freezer basket. If you know you have the same problem, Leave the ice in the freezer, unplug it, do the cleaning, and THEN remove the ice. This way the freezer stays frozen and nothing thaws. You can then take your time and the ice will be waiting for you when you are finished.
  3. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, The Problem is behind, not inside: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the fridge away from the wall making sure the water line isn't caught or pinched. You do not need to disconnect the water---but unplug the unit. Do not remove anything from the freezer until you are done cleaning the drain. Nothing will thaw this way.
  4. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Remove the panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are six screws. Two not shown are on the bottom of the left side. The heads are 1/4". No need to go near the panel above--its an electrical board.
  5. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Location of drain pipe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Location of drain pipe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I have unfortunately already removed the tube from this photo but you will see the tube in the following images. It hands down vertically in this spot. There is a secured hard plastic tube that leads into the fridge and a gasket that connects a drain tube to the part shown.
  6. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The tubing (not shown) just slides off the nipple. But I had water dripping onto the condenser. Place a sheet of plastic or paper, or anything to deflect the water away from the round horizontal part. The dripping will land on it. I used a plastic flexible cutting board and a container to catch the liquid--about 15ml?
  7. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the black gasket that connects to the fridge shown previously and the drain downspout. GE mentions replacing this but I can't remotely imagine why.
  8. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look inside the black adapter/gasket. This was full of scum. See how tiny the outlet is? This had to be the issue. If you just clean this, you should be fine.
  9. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now is probably a good time to vacuum all the dust. I also attached my shopvac to the connector to suck out any extra crap. Not sure if it helped. I also stuck a pipe cleaner up there and pulled out a bit more scum. I then flushed it with a turkey baster and warm water followed by clean water. Cover the condenser with plastic to keep it dry
  10. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Re-attach these 2 pieces and then attach them back to the tube in the fridge. Because the tubing is curved, it will take a mild amount of effort.
  11. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the back panel but try not to crush or pinch any of these tubes. Remember, 6 screws.
  12. GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Em: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Refrigerator GNE29GSH Clogged Drain tube, ice under freezer basket, Em: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Empty the drawers. Sadly, they will just dump everywhere if you try to be slick and reattach the drawers full. Remove the basket, clean out the skating rink of ice and the reattach. to do this, Slide out of the arms and place the basket in the notches. It should slide in easily.
mark.ladd
crwdns2935283:002/24/21crwdne2935283:0
438 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 51
