GE Front Load Washing Machine Not Draining - Drain Pump Replacement
crwdns2950213:0crwdne2950213:0
crwdns2950215:0crwdne2950215:0
      • Check that the drain hose is not inserted too far into the standpipe.
      • Ensure the drain hose has no kinks or damage that might block water flow.
      • Pull the hose back slightly if it's pushed in too deep to avoid siphoning or backflow.
      • Open the lower access area and remove the pump-filter cover at the bottom front of the washer.
      • Pull the plastic tray down to reveal the blue release knob on the pump filter.
      • Place a towel or tray underneath and slowly turn the knob counterclockwise to release water.
      • Use the knob to control the water flow until it fully drains from the pump housing.
      • Remove and inspect the filter for debris or obstructions and clean it thoroughly.
      • Pull the dispenser drawer all the way out and press the rear tab to release it.
      • Remove the five screws in the dispenser housing with a suitable screwdriver.
      • A magnetic screwdriver helps if screws fall inside the housing.
      • Lift the left side of the console and push it right to free it from the washer.
      • Remove the three small screws along the top of the washer behind the console area.
      • Slide the panel forward and lift it up to access the top of the machine.
      • Detach or reposition the short wire harness if needed to gain more access.
      • Release the outer door-boot spring with a flat tool, then peel the boot away from the front panel.
      • Watch for sharp metal edges as you pull the gasket from the washer opening.
      • Remove the two screws holding the plastic door-lock trim on the right side.
      • Remove the additional two screws securing the door lock and lift its tab free.
      • Remove the nine screws around the bulkhead, including the screw near the dispenser area.
      • Tilt the washer carefully if you must remove three bottom screws, using a stable support.
      • Slide the air baffle free by releasing its retention tabs after removing the middle screws.
      • Lift the bulkhead up and pull it forward slightly to separate it from the washer frame.
      • Unplug the door wire harness on the left side to remove the bulkhead completely.
      • Make sure the washer is fully drained through the pump filter before removing the pump.
      • Use slip joint pliers to compress and slide the hose clamps back, then remove each hose.
      • Expect some residual water and place a towel underneath to contain spills.
      • Remove the two top screws securing the pump assembly with a short screwdriver.
      • Disconnect the wire harness on the pump before maneuvering the unit out of the machine.
      • Check the rubber hoses for blockages before installing the replacement pump.
      • Reconnect the wiring to the new pump first while you have more space to maneuver.
      • Align the pump with the rubber grommets and press it forward to position the screw holes.
      • Secure the pump with the two screws, feeling for the threaded openings if working blind.
      • Reattach both hoses, ensuring the black hose notch is oriented correctly, then clamp them.
      • Reconnect the left-side wire harness behind the bulkhead before reinstalling it.
      • Lift the bulkhead above the washer chassis and lower it onto its plastic mounts.
      • Reinsert the bulkhead screws, beginning at the outer edges and moving toward the center.
      • Guide the door boot fan assembly into its slots and secure it with the related screws.
      • Reattach the door lock properly, adding two screws, then replace the plastic facade.
      • Press the door boot gasket back onto the metal lip around the front opening.
      • Stretch the door boot spring back into place using a door boot spring tool or zip ties if needed.
      • Slide the washer's top panel into position and secure it with the three mounting screws.
      • Hook the console onto the two large screws on the right and push left to lock it.
      • Hold the dispenser housing firmly while installing the five screws, with the two larger in the middle.
      • Insert the dispenser drawer fully and ensure it latches securely in place.
      • Run a drain or spin cycle to confirm the washer now drains and spins properly.
      • Check diagnostic codes or measure control board output voltage if the issue persists.
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
crwdns2935283:001/21/25crwdne2935283:0
7,128 crwdns2915208:0crwdne2915208:0
crwdns2935297:0224crwdne2935297:0
It looks like you can do what you've posted without having to take off the top panel of the machine- My machine is stacked with the dryer above. Could the machine be taken apart and drain pump replaced without removing the top panel- i.e., not having to unstack the machines? Thank you!
Sara Levine Kornfield - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 115
crwdns2936753:030crwdne2936753:0 614
crwdns2942667:0crwdne2942667:0 7,500
