GE Front Load Washing Machine Dispenser Assembly Replacement
crwdns2950213:0crwdne2950213:0
crwdns2950215:0crwdne2950215:0
      • Pull the dispenser drawer forward until it stops.
      • Press firmly on the tab at the rear of the drawer and slide the drawer completely out of the housing.
      • Use a Phillips screwdriver to extract the five screws now exposed in the dispenser opening.
      • Keep the coarse-thread middle screws separate from the fine-thread top and bottom screws.
      • Lift the left side of the interface about twenty degrees then pivot it to the right and pull it away from the washer.
      • Do not yank; the panel is still tethered by a short wire harness.
      • Press the three harness clips from the inside out if you need more room to maneuver the interface.
      • Unscrew the water valve assembly and pivot it upward to gain clear access to the dispenser body.
      • This procedure is easier on GFW-550 models than on GFW-650 and larger machines.
      • Unhook the wire harness from the dispenser body.
      • Release the top hoses that run between the water valves and the dispenser ports.
      • Slide the dispenser toward the rear to unlatch its right side from the chassis.
      • Loosen the clamps and pull off the four or five hoses attached to the back of the dispenser box.
      • If a hose is stuck, slip a flat screwdriver between the rubber hose and the plastic barb to break it free.
      • Remove the three screws underneath the washer to release the lower edge of the front panel.
      • Extract the seven screws securing the panel to the bulkhead.
      • Unscrew the two screws holding the door-lock facade and the single screw securing the lock.
      • Lift the lock upward and push it rearward so it will not snag the panel.
      • Open the washer door, lift the panel upward, and pivot it away from the machine.
      • Disconnect the wire harness on the left side before fully removing the panel.
      • Remove the spring clamp and pull the primary tub hose off the dispenser spigot.
      • Disconnect the drain hose at the underside rear of the dispenser.
      • Release the small hose behind the metal plate next to the dispenser box.
      • With all eight hoses free, slide the dispenser box out of the cabinet.
      • Inspect or clean the box now, or set it aside if you are installing a new unit.
      • Unclip the reed switch from the underside of the old dispenser and install it in the same location on the replacement box.
      • Feed the rear drain hose onto the dispenser first before the box is fully seated.
      • Slide the dispenser into the front bulkhead opening and hold it in place.
      • Attach the remaining seven hoses one by one, securing each clamp firmly.
      • Work patiently; reinstalling the hoses usually goes faster than removal.
      • Route the harnesses into the molded channels on the dispenser body.
      • Slide the dispenser rearward until its rear hooks click into the washer chassis.
      • Reconnect the large front hose, aligning the molded notch with the dispenser groove.
      • Confirm the small alignment finger rests on the bulkhead to guide the dispenser box.
      • Lift the door panel onto its four locator pegs and push it flush with the cabinet.
      • Reconnect the left-side harness, then replace the upper and lower mounting screws.
      • Ensure the top damper is fully seated, then install its three mounting screws.
      • Roll the door gasket lip over the rim and wear gloves to avoid cuts.
      • Expand the spring with a door gasket spring tool and guide the wire around the gasket groove.
      • Use a small hook or screwdriver to press the wire fully home before releasing the tool.
      • Position the door lock on its bracket and secure it with its screw.
      • Reattach the plastic facade using its two screws.
      • Hook the interface onto the right-side post, pivot it down, and snap it into place.
      • Install the two coarse-thread center screws and the three fine-thread outer screws while holding the dispenser box flush.
      • Slide the dispenser drawer back onto its rails until it clicks fully home.
      • Lower the top panel onto the chassis and secure it with its rear screws.
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
crwdns2935283:001/21/25crwdne2935283:0
7 140 crwdns2915208:0crwdne2915208:0
crwdns2935297:0224crwdne2935297:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 929
