GE Carescape R860 Alarm Light (PWA) Board Replacement
  1. GE Carescape R860 Alarm Light (PWA) Board Replacement, GE Carescape R860 Display Unit Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
  2. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the seven screws that hold the rear housing using a Phillips #0 screwdriver.
    • Remove the rear housing.
  3. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the cable tie holding the two cables at the lower right side using scissors.
  4. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the touch controller cable.
  5. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Keypad harness at the Carrier Board.
  6. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the encoder harness from the Carrier Board.
  7. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker harness from the Carrier Board and set the speakers aside.
  8. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the alarm light harness from the Carrier Board.
  9. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen (do not remove) the five screws at the top edge of the shield just enough to raise it and slide the shield away with a Phillips #0 screwdriver.
  10. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the four screws along each side of the shield with a Phillips #0 screwdriver.
  11. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws at the bottom edge of the shield with a Phillips #0 screwdriver.
  12. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the shield down to disengage the touch controller harness connector.
  13. GE Carescape R860 Alarm Light (PWA) Board Replacement, Alarm Light (PWA) Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the PWA board from the slot.
    • Replace the PWA board.
  14. GE Carescape R860 Alarm Light (PWA) Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the alarm light harness.
Andre Fisher
crwdns2935283:001/23/20crwdne2935283:0
357 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G9, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G9, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G9
crwdns2942667:0crwdne2942667:0 389
