GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement
  1. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery Compartment Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery Compartment Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery Compartment Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, LCD Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Clock Radio: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Clock Radio: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery Wires Wire Tie: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Battery Wires Wire Tie: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the wire cutters, carefully cut the plastic wire tie.
  7. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the speaker.
    • Lift the speaker from the holder.
  8. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Two Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Two Screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two 6mm screws on the PCB.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws from the PCB.
  9. GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Four-Position Switch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE 7-4836B Alarm Clock AM-FM Radio On/Off/Music/Alarm Switch Replacement, Four-Position Switch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four-position switch marked SW101. On the underside of the PCB, there will be 4 soldered pins as pointed at in the picture.
    • Apply the hot soldering iron to those four soldered pins to disconnect the four-position switch.
Dominick Giguere
crwdns2935283:010/28/14crwdne2935283:0
848 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,062
