GD Midea FT30-3D Oscillation Mechanism Replacement
  1. GD Midea FT30-3D Oscillation Mechanism Replacement, Fan Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Oscillation Mechanism Replacement, Fan Blades: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spinner from the center of the fan blade.
    So how do i take the spinner off the fan
    Martha Meza - crwdns2934203:0crwdne2934203:0
    H how do I take the spinner off the center of a fan I don't know how
  4. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
  5. GD Midea FT30-3D Oscillation Mechanism Replacement, Oscillation Mechanism: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
    • The plastic nut needs to be twisted off; like a screw.
  6. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
    • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
  7. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front motor housing by removing 4 screws.
  8. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
  9. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
    the two wires of capacitors are connected where ?? please guide me.
    mohangmysore - crwdns2934203:0crwdne2934203:0
    The two wires are normally connected to the motors, start winding.
    james - crwdns2934203:0crwdne2934203:0
  10. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw that connects the oscillator to the rocker arm.
    • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
  11. GD Midea FT30-3D Oscillation Mechanism Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The oscillator should now be easy to pull off.
    • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
crwdns2935229:011crwdne2935229:0
Alan Su
crwdns2935283:010/03/12crwdne2935283:0
834 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-28, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G28
I bought a fan and two days later my grandson dropped it and it stopped turning. Its been stuck in one position for about two weeks. Finally I said I know someone on the internet is gonna no what is wrong and how to fix it. Thank you. I fixed my fan in about 10 minutes. The oscillating handle had just come lose from the screw. Everybody thinks I'm a genius. LOL! Super grandma strikes again!
kim - crwdns2934203:0crwdne2934203:0
Where do I locate a gearbox kit for a 30” polar aire fan model lfdj-30pbo. Thanks for what ever help you can give me
Eric Delatte - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 14,529
