GD Midea FT30-3D AC Power Cord Replacement
  1. GD Midea FT30-3D AC Power Cord Replacement, Bottom Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
  7. GD Midea FT30-3D AC Power Cord Replacement, AC Power Cord: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15 mm Phillips screws on the retention plate.
    • The tan retention plate will fall off once the screws are removed.
  8. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the AC power cord white wire. Press into the hole gently to release the grip on the wire.
    • The AC power cord wire should release with ease if done properly.
  9. GD Midea FT30-3D AC Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the existing cable tie bundling the other AC power cord, red, orange, gray, and blue wires together.
    • Remove or cut the crimp connector connecting the blue wire and the AC power cord wire.
  10. GD Midea FT30-3D AC Power Cord Replacement, AC Power Cord: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the new AC power cord and follow the steps in reverse order.
    • It will help to use a soldering iron to solder the tip of the wire that gets inserted into the power/speed switch.
    • You may need a new cable tie and wire terminator with the new power cord.
crwdns2935229:05crwdne2935229:0
Chris Hartley
crwdns2935283:010/04/12crwdne2935283:0
438 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-28, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G28
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 264
crwdns2942667:0crwdne2942667:0 2,486
