crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide is used to replace or swap the cord/paracord on the G-Wolves Hati mouse.
The paracord is the wire which connects the mouse to the computer and allows the mouse to function and guide the cursor. It is a lighter form of cable which is used in gaming mice in order to alleviate the feeling of having a cable attached to a mouse. With a faulty paracord, the mouse sensor could not only be stuttering, but there is a chance the entire mouse will disconnect or not function whatsoever (even if the rest of the components are all in working condition).
Steps 2 and 3 involve removing mouse skates from the feet. Be careful not to create, bend, or fold lines on these feet as they will be felt when moving the mouse. Peel them slowly.
Make sure to have the mouse disconnected before beginning the guide.
Flip your mouse upside down.
Unscrew both of the uncovered screws.
Squeeze the mouse under second mouse button until the bottom opens.
Pull the bottom piece towards the back of the mouse and upwards to remove it.
Remove the ribbon cable connecting the bottom piece to the upper piece.
Unscrew the following screws:
4.8 mm Phillips-head screws.
Flip the bottom piece upside down.
Pull the circuit board off without pulling on the cable.
Grab the side ridges and remove the connection.
Pop off the paracord from the bottom piece.
Rearrange wires to follow the guide ridges.
Re-insert the circuit board by lining up the scroll wheel with the front piece and pressing down.
Thread the wire through the side opening.
Insert the paracord connection.
Hover the bottom piece over the upper piece flipped over.
Press the bottom piece down and forward till under clip pieces.
Press down where skates where removed till there is a click.
