Furbo Dog Camera USB Power Jack Replacement
  1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
    On the MAX model that I disassembled, there were two Phillips head screws through tabs on the front half, holding it in place. I had to remove them so that the front half could be removed.
    MARSHALL PRYOR - crwdns2934203:0crwdne2934203:0
  5. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
  7. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have removed the screws, gently pull the bundled cable connector free from the motherboard.
  8. Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Furbo Dog Camera USB Power Jack Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The USB power jack PCB can now be removed from your Furbo and replaced.
    Wo bekommt man die Platine mit dem USB...
    roland.veigl - crwdns2934203:0crwdne2934203:0
    Have this issue. Where do over the USB Power Jack replacement?
    Jessic Upperman - crwdns2934203:0crwdne2934203:0
    Need a replacement for the usb
    Mich - crwdns2934203:0crwdne2934203:0
Piper Strgar
crwdns2935283:003/21/22crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-1, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-1, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G1
Where can you find a replacement
Brandon Alves - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,592
