Removing 10x Case screws
Use a PH#1 driver or bit to remove the 9, 7.5mm, M2 screws
Remove, 4, PH#1, 4.5mm, m2 screws.
insert your jimmy tool vertically in the gap between the side a buttom pannel
Use a gentle twisting pressure to create a gap for a plastic opening pick or spudger
pry the borders of the back pannel
You can gently lift the bottom-most section to assist in separation
remove the back case
remove the 8 ph#1 bit screws from the battery
set the battery aside
remove 1 more ph1 screw from the m.2 braket
lift the bracket and card out gently
this step is optional
removing and reinstalling the CMOS battery will cause a warning on boot however, this step can reset any firmware-related issues. simply press enter to boot past the warning message.
CMOS battery removal is a common trouble shooting step as it can solve many software-related failure modes.
remove the black and white antenna wires from the fan shroud
unplug the black and white antenna cables from the wifi card
unscrew the single ph1 screw from the m.2 wifi card
unplug the fan connector
unscrew 3 ph1 screws from the fan assembly
gently pry away the blower fan
you got that sucker out clean it up real good.
remove the ram cover sticker
the next parts of this step are optional
remove dram
clean off the thermal paste with 99% isopropyl alcohol & a q tip
Guide written by Daniel Layman, CEO & co-owner of Advanced Device Repair, LLC
Do you happen to have a guide on how to replace the keyboard for this model?
