Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
  1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector with an ESD-safe spudger.
  18. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
    • Gently separate the MicroSD card from the device.
Casey
crwdns2935283:003/25/19crwdne2935283:0
283 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G1, Henning Spring 2019 crwdns2935289:0IUPUI, Team S1-G1, Henning Spring 2019crwdne2935289:0
IUPUI-HENNING-S19S1G1
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 619
