If your Lifebook won't connect to a wireless network this guide will show you how to replace a wireless adapter so your Lifebook will get a signal.
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to disconnect the ribbon cable from the motherboard.
With the tweezers detach hinge cover cables from the motherboard.
Remove hinge cover.
Lift keyboard enough to show the ribbon cable.
Use a plastic opening tool to release the ribbon cable from the motherboard.
Push the secure clips outward.
The Adapter should pop up.
Use tweezers to remove the wires from the Adapter.
Take out the Adapter and carefully pull the wires out from the metal casing.
Je suis vraiment intéressé merci.
Ravi de la leçon.
Jean Fella - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
