Fujitsu Lifebook S6120 Fan Replacement
  1. Fujitsu Lifebook S6120 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Fan Replacement, Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  12. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  13. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon from the motherboard with a pair of tweezers.
  14. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 5mm nut driver to unscrew the nuts.
  15. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ribbon tab up and off the motherboard.
  16. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plate covering the motherboard.
  17. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  18. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch your fingers around the base of the connector and pull it out.
  19. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard off the plastic base.
  20. Fujitsu Lifebook S6120 Fan Replacement, Fan: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Fan: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement, Fan: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
  21. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers detach the cable from the motherboard.
  22. Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook S6120 Fan Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fan can now be removed from the motherboard.
Jessi Gallant
crwdns2935283:003/19/18crwdne2935283:0
899 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G5, Peak Spring 2018 crwdns2935289:0UMass Dartmouth, Team S5-G5, Peak Spring 2018crwdne2935289:0
UMASSD-PEAK-S18S5G5
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 841
